This command configures a keychain accept tolerance in seconds.
| keychain_name | Specifies the name of the keychain. |
| accept-tolerance | Specifies the length of time an expired key can be accepted for received packets. |
| seconds | Specifies the tolerance in seconds. Range is 0-600 (default is 0). |
The default is 0, no tolerance.
Use this command to configure a keychain accept tolerance.
The following command configures the keychain accept tolerance:
configure keychain accept-tolerance 55
This command was first available in ExtremeXOS 31.3.
